Asian skin merchant
colinmac2colinmac2 Posts: 407
Have bought and downloaded this (fairly expensive) resource, I am surprised to discover that it seemingly appears NOWHERE in my products list! I assume I'm looking in the wrong spot, but where am I supposed to find it and is there any documentation on it?
    This is a Merchant resource, meaning it contains only JPG and PNG files to use in making your own texture sets.
    The idea of a MR kit is that you use it in a paint program, so it will not install to your 3D program, but rather needs to be installed in a folder elsewhere which you can then access in your paint program of choice.
    The readme is here http://docs.daz3d.com/doku.php/public/read_me/index/19813/start
  • Cris PalominoCris Palomino Posts: 13,062
    Depending on the product, some MRs have presets to see the skin, and other provided pieces, on the target model. However, more often, they are only the textures. They should never be used as is, unless for private use, and even then they are not intended to be perfect since they are resources and expected to be corrected and changed as your needs require.
