Sending hexagon mesh back to DS4.6, but after the prompt, I don't see the morph dial
tmtmtm_f56c8d4bdatmtmtm_f56c8d4bda Posts: 86
I'm loading a G2 figure and send it to Hexagon 2.
Then I edit some vertices, and send the figure back to DAZ STudio 4.6
At the prompt, I keep everything as-is. Save as new morph, and save it to morphs/hexagonmorphbridge or some such, and name it "my morph blah blah".
First off, there is no section "Morphs" in my shaping panel. Why? Do I need to turn that on somewhere?
I tried saving the morph to "Actor" and other folders below, but nothing. It's just not generating a morph dial.
What am I doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 111,718
    If in doubt, check the Parameters pane - that should always show everything, unlike the sub-panes such as Shaping. Is the morph in the Parameters pane?
  • tmtmtm_f56c8d4bdatmtmtm_f56c8d4bda Posts: 86
    Yup. Thanks oodles!
    OK, to get it showing in the Shaping pane you need to open Parameter settings (click the gear icon on the morph's slider) and set the Type to Modifier>Shape - it also, as I recall, needs to be in the Actor group.
