Measure Metrics for DAZ Studio Plugin failed to Load.
I have no idea why this is failing. Manual install, DS 4.12.0.86. Anyone have some suggestions?
Late , going to bed. Ill pick back up on it in the  morning. Thanks.
  • fixmypcmikefixmypcmike Posts: 19,734
    Was the plugin zip downloaded at the same time as DS 4.12?  The version of the plugin needs to match the DS version.
  • AnotherUserNameAnotherUserName Posts: 2,727
    edited February 2021
    Ok, that makes sense but im not sure which file that would be. These are the windows files that I see listed:
    IM00016684-21_FigureMetricsforDAZStudio46Content.zip - I installed this.
    DS4_MeasureMetrics_1.8.0.2_Win32.exe - Im assuming its notthis becasue im on a 64bit system.
    16684_FigureMetricsforDAZStudio46Win_1.4_ds.exe
    DS4_MeasureMetrics_1.8.0.2_Win64.exe
    Other than the mac files, this is all thats available for Manual dl.
    If I install DS4_MeasureMetrics_1.8.0.2_Win64, this version gives me the plugin failed notice. So if I install 16684_FigureMetricsforDAZStudio46Win_1.4_ds , it dosent show up in my plugin list at all.
    I dont see a pane for it either.
    Post edited by AnotherUserName on
  • The final numbers have to match - the plug-in requires DS 4.15.0.2.
  • So this will only work with the current version of daz? Didnt this come out some time after G2 did?
    The plugin is updated with each release.  You would have to contact Customer Support to see if they can get you the version matching your DS version.
    OK, thanks Mike.
