Is it posible to aply caracter morph to just some clothings?
I know I can turn off following for a morph on the character and this will stop clothes from following.
However in this setting I want the pants to have the leg morph but not the tail as its deforms it.
http://i.imgur.com/W0ALX9R.png
Removing auto follow on figure remove morph from all items after reload.
Keep auto follow but override on tail works until reload, then it get the value back.
Wonder if its an solution here?
  • fixmypcmikefixmypcmike Posts: 19,731
    Select the clothing, and on the Parameters pane make sure "Show Hidden Parameters" is turned on, then you can dial down the auto-follow morph on just that item.
  • edited December 1969
    Thank you it worked, so simple, I was always messing around with turning off auto follow on the clothing part who would then be reset on save and load.
  • MasterstrokeMasterstroke Posts: 2,510
    in order to make clothes follow my custom morphs with G2F, is it that, what I need to do?
    where is that "Show Hidden Parameters" you mentioned? I cannot find it. Could you please post a screenshot? thx :)
    For clothes to follow morphs Autofollow needs to be set to 1 on the morph. This lets you turn off those automatically generated morphs in the clothing.
    349 x 326 - 41K
    Ahh cool :) . Thx for help.
