From DAZ Install Manager to DAZ Central
Hi there,
I have the feeling that DAZ Central is the better solution when it comes to the management of DAZ products from the DAZ store and also thirdparty content and I have yet to make the shift.
I have tons of products installed through the manager and I am wondering if there is a smart way to make the shift from the Install Manager to Central?
Should I do this in a particular way or just plain deinstall the Manager and install Central?
Some tips would be very helpful, in case there are things that could waste a lot of time or create problems if not done correctrly.
Or maybe it's simpler than I think?
    Central is a dumbed down version of DIM, don't change.  Furthermore neither Central or DIM can install content from other sites.
  • Daz Central should pick up your DIM settings, though I would not think it likely to be abetter solution for an experienced user - the whole point is to simplify things for new users.
    DIM can install content from other stoes (or freebies) if it is correctly set up, but of course most isn't.
    I have noticed the rather difficult process with some 3rd party content.
    I was hoping to see things somewhat evolved with Central but it seems that's not the case.
    That's really good to know!
    Thank you!
    Thank you! I am actually glad that I can just keep using DIM. It seems to work pretty well for the most part.
  • Try RiverSoft Art's Content Wizard for zips from other sites
    Thank you! Will check it out!
  • NorthOf45NorthOf45 Posts: 5,923
    There is also Content Package Assist that can make DIM-compatible zips. No Smart Content, though. Generating it automatically from the contents requires some measure of magic to do more than a simple parts list.
    Nice!
    Maybe one day I will need such a tool.
