G8 - Chest deformed when mode raises his/her arms.
Hi there
I've been trying to resolve this but still no luck. My models started havgin this issue, whenever I raise their arms, their chest shape also changes and completely deformed. I've attached a move showing it. Looks like nipple sticks out when arms are listed. So somehow two movements are connected.
Do you know how to resolve this?
Thanks!
  • DireWorksDireWorks Posts: 135
    cant recognize the deformations maybe better attach 2 images, default pose and posed
    in parameter tab check the wheel right to the heart, parameter settings, of the slider that gives you the issue (collar bend maybe?)
    and check what is connected (ERCs) you should only see collar related morphs and 1 pectoral, if i am not wrong
    in any case if there is something about the nipple it should be an error,
    also load the development base character  and check if there are active morphs with a default value non zeroed
    in that case set the default value to zero in the same parameter settings window and overwrite that single morph asset
    or you can reinstall all the g8 package, if there is an error for sure is not about the original files
