Daz Studio Broken (Again) With a New & Thrilling Problem to Tantalize Frustration
Rufus CoppertopRufus Coppertop Posts: 178
edited January 2021 in Daz Studio Discussion
In addition to the return of problems I thought I'd fixed yesterday with help from Richard and others, the problems are all back.
When I try to customize a figure with the elongate abdomen morph in Shape Shifter, the shoulders burst up through the tanktop straps and the hair which was on the head is now a nose level beard.
It only happens with that morph.
And now for the NEW & THRILLING BONUS PROBLEM...................I can't select anything in the scene workspace. There's a little red circle rather than an actual arrow cursor.
Post edited by Chohole on
  • SimonJMSimonJM Posts: 6,100
     That sounds like you have a Tool other than Node Selection or Universal selected.
  • nicsttnicstt Posts: 11,715
    It sounds like Daz isn't broken, but you have a different issue; what SimonJM said basically, is the much more likely scenario. The red circle is a feature of a different tool.
  • PetraPetra Posts: 1,157
    It sounds that the hair and clothes are not fitted to the character, so when you add this morph, the character gets taller and with that everything that is not fitted or parented will not move with the characters body when it is changed.
  • The red circle is from the animate2Tool. You should select the "SelectionTool" from the menue-bar (or press ALT+Shift+V)
    622 x 200 - 40K
  • Red circle is likely to be the Geometry Eduitor (which I did have you turn on looking for Rigidity Groups in yoru other thread).
    An issue with Shape Shufter does sound vaguely familiar
    They actually are fitted though. I use the transfer utility and when I select a body part in the scene tab (but not in the larger scene workspace - because little red circle) and then use the pose slider, the body and garment do actually pose. The hair is fitted and parented and poses as well except when I use that one particular morph in question.
    I've fixed the red circle. The solution was sooo obvious. Click the select tool and get the select tool.
    The Shape Shifter thing is still a problem AND following the suggestion you gave about FIT TO MODE which did work the first time I tried it, no longer works.
    I might have to get in touch with the people who made Shape Shifter and see if they have any suggestions.
    Is all clothing and hair or only some?  I have used that morph quite often and have not had the problem you are descibing.  I seem to remember that the Growing Up morphs had this problem with somethings.
  • I have earlier versions of the characters clothed in my library that work perfectly. It's new versions of the garment (or newer) that have this problem.
    I'm sure I'll get it sorted eventually even if I need to reinstall the shape shifter thing.
  • I still think you overwrote something in your data accidently saving a figure as a support asset
    try moving the data folder out that bears your username
    for example
    your drive letter:\My DAZ 3D Library\Data\DAZ 3D\Genesis 3\Male\Morphs\wendyluvscatz
    I:\My DAZ 3D Library\Data\DAZ 3D\Genesis 3\Female\Morphs\wendyluvscatz
    I have some pieces of clothing that are converted from older Genesis generations and while they do mostly fit, when the height of the character is changed, the clothing does not seem to understand the height change.
    Haven't had time to figure out the problem, as it doesn't happen with all height and/or proportion changing morphs.
    for example
    I think you're going to turn out to be absolutely correct.
    And when you do I'll be happy to let you know and post the solution in case others have the same problem.
    for example
    I:\My DAZ 3D Library\Data\DAZ 3D\Genesis 3\Female\Morphs\wendyluvscatz\
    And guess what?
    You're absolutely right!
    I don't know exactly what the problem was but I went through my library like a dose of salts and scoured out a whole lot of stuff.
    Then when I loaded Gen 3 Base figure and loaded hair to test it and reset the morph and played with it, it all worked perfectly.
    Thank you. Thank you very, very much.
  • it is easily done, I know from experience accidently doing itblush
