Genesis 8 Female not loading correctly
Since updating Daz Studio, The Genesis 8 Female does not load correctly. It loads with a face already on it. I've uninstalled and reinstalled everthing a couple of times with no change. If I load the Genesis 8.1 Female, it loads correctly but it won't let me make any changes to it. Could I have deleted something that I needed? Any help would be greatly appreiciated.
Please remember to put the Viewport into Smooth Shaded Drawstyle if you are going to show a nude figure, or if you need to show only the face just foom in on the head.
This usually means that something was installed witha non-zero default value, so that it loads pre-applied. As it is not affecting Genesis 8.1 I would suspect it is an expression rather than an actual shape. One fix is to load the Genesis 8 Female Dev Load, Edit>Figure>Zero>Zero Figure, then File>Save As>Support Assets>Save Modified Assets (though this won't work if the pronlem item was installed through Daz Studio itself).
