Smart Content is gone
vintorixvintorix Posts: 220
edited September 2014 in New Users
Since I downloaded DAZ Studio 4.6.3.52 my Smart Content has disappeared. I can live with that but what is more serious is that when I save a clothing item as SupportAsset Figure/Prop/Asset, the various choices for "Set Content Type" never come up and likewise "Set compatible with" is empty. How important is it that those fields are filled in? And how can I make the premade list of choices come back? I have checked that the contentmanager is running.
Post edited by vintorix on
  • TotteTotte Posts: 15,214
    Did you install the Content Manager Update to Postgres or are you still running Valentina CMS?
  • vintorixvintorix Posts: 220
    Thank you Totte, for trying to help
    "Did you install the Content Manager Update to Postgres "
    No
    I am quite willing to start from new. But even after a complete uninstall of everything and cleaning the registry the program still finds my old installation settings somehow. What is needed is a program that completly clean the computer from everything Daz so you can start from a virgin state!
    What I have now is a clean install (DAZStudio_4.6.3.52_Win64) and a new Main library with a name I never used before with only the GenesisStarterEssentials installed. But still smart content and product categories etc are missing. Whether the Daz Content Manager Service is running or not have no significance.
    Shall I install postgreSQl? Is "installing Content Manager Update to Postgres" the same as running DAZPostgresqlCMS_9.3.4.exe?
    Well, I exported the user data and installed postgreSQL.
    Now, in my CMS Settings in Preferences I have
    Cluster Directory: C:\users/Appdata/Roaming/DAZ 3D/cms
    Port:17237
    But the logfile in that directory says:
    LOG: test message did not get through on socket for statistics collector
    LOG: trying another address for the statistics collector
    LOG: disabling statistics collector for lack of working socket
    WARNING: autovacuum not started because of misconfiguration
    HINT: Enable the "track_counts" option.
    LOG: database system was shut down at 2014-09-26 22:23:24 CEST
    LOG: database system is ready to accept connections
    LOG: received immediate shutdown request
    postgres cannot access the server configuration file
    "C:/Users//AppData/Roaming/DAZ 3D/cms/ContentCluster/postgresql.conf":
    No such file or directory
    And indeed there is no file postgresql.conf. And of course. Smart content is still not working or anythin else
    that has connection with the CMS.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Are you using ZoneAlarm as your firewall? That is known not to work with PostgreSQL.
    The Update to PostgreSQL is not PostgreSQL, it a tool for converting your daatbase from Valentina to PostgreSQL and should be run after installing the actual PostgreSQL database engine.
    Well thank you Richard as usual you give me a hint in the right direction. I am not using Zonealarm but my Window 8.1 intrisic firewall may still be the culprit. I will make another try. And where can the tool for converting your database from Valentina to PostgreSQL be downloaded?
    The converter should be listed in the Install Manager.
    Disabling the firewall didn't help so I am leaving this for now. After all my partner can resave the cloth items and set category so I am not in an impossible situation. Thanks again for trying to help, it is much appreciated.
    I am back with a working DS. This page by Kraig Hausmann explain it all without leaving out even the tiniest detail,
    https://helpdaz.zendesk.com/entries/22523891-Trouble-shooting-the-Smart-Content-Pane
    adjective: thoroughly
    complete with regard to every detail;
    synonyms: in-depth, exhaustive, thoroughgoing, minute, detailed, close, meticulous, scrupulous, assiduous, conscientious, painstaking, methodical, careful, sedulous, complete, comprehensive, elaborate, full, intensive, extensive, widespread, sweeping, searching, all-embracing, all-inclusive
    Naturally the author was German!
