Error missing Genesis Michael 5 UV Maps
SnowDogz1SnowDogz1 Posts: 0
I bought Walker HD for Genesis but I get an error about missing Genesis Michael 5 UV maps?
Should Walker files have the missing UV maps with it?
I'm Lost
Randy
  • Richard HaseltineRichard Haseltine Posts: 111,996
    The Michael 5 UV set comes with Michael 5. It sounds as if that should be listed as a required product, assuming it is in an area that matters (if it's just the eyes, for example, I'm not sure it will hurt, warnings aside, not to have the UV set). Does the figure appear to be textured correctly? if it does you should be safe to continue, though regardless I would urge you to make a report to Technical Support as the reference should be fixed (if it doesn't matter) or M5 should be added asa required product (if it does matter).
  • a51_aliena51_alien Posts: 15
    I Just had this exact problem.
    I went back to the product page and it does actually state : "This product uses the Genesis Michael 5 UV Maps"
    However, that "warning" is in the "features" section... It should be in the "requirements" section :(
