Genesis female smile problem
when a closed smile the lower lip rises strongly, which contradicts the anatomy and creates a monster
compare with a mirror This problem is quite old - when will you fix it?
  • Might want to provide some specifics as to what you're talking about.
    What mesh, g8f/m, v/m4, etc. are you working with?
    are you using a preset or a morph dial?
    Could you provide images of what you mean, render vs real world?
    If a particular morph or preset isn't producing the results you want, you may want to try some adjustment morphs.
    Try adjusting the various morphs under Pose>Head>Mouth>Lips. this is for g8f and may vary for other figures.
  • MasterstrokeMasterstroke Posts: 2,523
    edited January 2021
    Epressions always look horrible on custom characters. That is in the nature of things, for epressions are made for the base G8Female only.
    There is no other way, than creating your own custom expressions for each and every character seperatly, you are going to use. So consider those pre-set expressions as resources.
    BTW: are you using "Auto Face Enhancer"? The morph targets coming with it, are sometimes dialing in with your expressions and exaggerating those.
    Post edited by Masterstroke on
