How do you save an ACTOR (Character) with hair, brows and Anatomical Elements?
ericwestrayericwestray Posts: 83
edited January 2021 in The Commons
Hi Everyone,
Can you tell me how I can save my characters as ACTORS, so I can just merge them into scenes and they load
with their hair, brows and gentialia already attached. Is there a way to do it other than saving them as a Scene Subset?
Post edited by Chohole on
  • I use scene subset and merge. Is there a reason that this won't work for you?
  • Lee MoonLee Moon Posts: 940
    I also save characters with their hair, brows, sometimes clothing, etc. as a Scene Subset and load them into new scenes.  I do this several times a day.  Works perfectly.
    Lee
  • Yes, that totally works for me too, but I thought I have purchased characters that are "ACTORS" that load with everything on them.
    You know with the little blue actor tab. I was hoping there was a way to do the same thing.
    I thought I could create a folder with all my characters as "actors" and not with the little green "subset label."  LOL
    A character preset can do that, but the post-load script it refers to(which by default just loads the lashes on Genesis 8 figues) needs to ebe dited to handle any other add-ons, it isn't an automated process.
  • BejaymacBejaymac Posts: 2,010
    edited January 2021
    https://www.daz3d.com/forums/discussion/comment/5502206/#Comment_5502206
    ^^^^^^^ a quick run through on what Richard is refering to.
    Post edited by Bejaymac on
  • PetraPetra Posts: 1,157
    I always save a scene subset and you can then merge into a scene.
  • kgrosserkgrosser Posts: 141
    I do it differently and save my characters as morphs, and the rest at a "loaded" wearable. Thiswon't save the actor but has other advantages as clothes better audio fit bar characters then morphed into shape.
    theres a thing in the character preset to post load a script.  can mebbe re add the load eyelashes
    257 x 284 - 21K
  • Thanks, Everyone!
  • Silas3DSilas3D Posts: 836
    You should be able to load a scene subset without merging into the current scene, given the subset nomenclature - if something is saved as a scene, then there will be a warning dialogue saying the current scene will be cleared.
    That warning will only appear if your current scene isn't saved. Many a time I've accidently double-clicked a scene file only for my current scene to close and the new one to open instead of merge. Generally if I'm adding a saved scene I'll right-click merge and delete the things I son't want, like lights, tonemapper options etc. but sometimes I'm half asleep and forget.
  • PlatnumkPlatnumk Posts: 682
    Try using the following
    File - Save As - Support Asset - Figure/Prop Asset
  • LeanaLeana Posts: 13,618
    edited January 2021
    That saves a completely new figure, not a figure and accessories. So I don’t think that’s what the OP wants to do.
    Post edited by Leana on
