Render time - Daz Lions - How to reduce
IGDIGD Posts: 0
I have a scene with multiple lions and I can affor 3d Ded a bit of quality reduction to save time.
Are there specific settings for the Daz lion that I can tweak to reduce render time?
  • FishtalesFishtales Posts: 6,244
    If you have more than a couple of males then reduce them as I was told the manes take a lot of rendering time.
  • Scott LivingstonScott Livingston Posts: 4,352
    Which lion are you using? If it's this one or another version that uses transmapped hair for the mane, then there are some things you can do to get the mane to render more quickly. If you convert the mane to the UberSurface shader, you can turn Occlusion and Raytracing off...this should help a lot. I have some detailed instructions on the process in my hair tutorial.
  • IGDIGD Posts: 0
    Yes it's the new one. The render time is awful comparatively despite the great results. I'll try your suggestions. Thank you :)
