temple of mars
ISIKOLISIKOL Posts: 386
i Urgently need your help.!
i purchased temple of mars but even though it says its compatible with poser in the product page i see no such files...
http://www.daz3d.com/temple-of-mars
i bought the bundle product but i dont think that its relative...
is there anyone who could convert this for me to poser?
thank you so much!
    It states in the description that it's for Daz Studio only. In fact, it goes a step beyond since it's old Daz and not the new DUF format. Unfortunately, while some may be able to convert it to Poser no one would be allowed to give you the resulting file as that would be breaching the EULA.
    In this instance, you're probably better off contacting Daz 3D about a refund.
  • ISIKOLISIKOL Posts: 386
    i already contacted daz....the image below says something else...i usually dont read everything than the compatible software field...
    749 x 900 - 294K
    thank you so much!
    Just a quick note
    The only person who could legally convert this to poser for you is the vendor.
  • M F MM F M Posts: 1,388
    edited September 2014
    Yep, the product page certainly lists Poser there - however the .ZIP file contains only .dso files, no .obj's.
    Do you not have that DSON importer thingy for Poser?
    Post edited by M F M on
    @chohole im aware of that...thank you...i made this post hoping h will see it...
    @mfm...yes i do...what can i do please with this?
    I _believe_ you can use it to import the DSO files... hmmmmm... trying to find a manual or thread for you, not having much luck. Note, it is quite possible I'm wrong in this regard - I don't have a recent Poser to test with <(^_^) - hopefully somebody who regularly hops "between worlds" might be able to jump in and guide you.</p>
    I don't suppose you have an installation of DAZ Studio there as well? ... you could load the Temple, then export it directly as a .OBJ file. I'm guessing you don't really care about preserving the DS materials (using your own Poser mats).
    Correct me if I'm wrong, but I believe the DSON importer only actually works with DSON files (ie, DUF). However, as MFM pointed out, if you install Daz Studio you can easily export it either as a Poser compatible format for use in Poser renders.
    Yes, I'm getting that impression, Herald. The only thing the Temple product provides is a .daz file (which then calls up the .dso's)... I'm guessing that can't be pushed through the DSON importer directly.
    Ergo, depending on what Isikol has installed - I can confirm it really is a 30 second process to get the Temple read into DS and exported as a OBJ and then imported back into Poser (below in 2010... which unfortunately I don't have a version of the DSON Importer for, so I can't test directly >_<).</p>
    EDIT: oh, hang on, I CAN run the 32-bit DSON Importer in PoserPro-2010... trying now...
    EDITx2: blah >_<... python incompatibilities... so, no I can't help directly with the DSON Importer Isikol - please ignore what I said above. The path of least resistance (imho, and assuming you have a DS installation lying about) will definitely be Export .OBJ / Import. I can screenshot/walk you through that process if you need -- or, if you don't have the time to fiddle with a DS download and install, then I guess the temple won't be appropriate for your current project v(^_^)v.</p>
    1022 x 512 - 232K
  • Midnight_storiesMidnight_stories Posts: 4,112
    n/a
    Post edited by Midnight_stories on
  • robkelkrobkelk Posts: 3,259
    M F M said:
    Ergo, depending on what Isikol has installed - I can confirm it really is a 30 second process to get the Temple read into DS and exported as a OBJ and then imported back into Poser (below in 2010... which unfortunately I don't have a version of the DSON Importer for, so I can't test directly >_<).</div>
    If you can export the model to OBJ, why would you need the DSON importer? Just import the OBJ itself.
    Dimension 3D's DSF Toolbox
    http://www.daz3d.com/dimension3d/dsf-toolbox
    Does file conversion for older DS formats. You might want to take a look at it.
    hey guys!!! i have lost all my working day with this thing...i have the latest studio install...can anyone PLEASE give the steps to import it and then export it to whatever poser opens...? PLEASE!
    Step1
    select the prop or figure you want to convert, and from the menu chose "Create Poser Comp Files"
    Step2
    Fill the Box out like so see screenshot
    Now this could dump it in a few places so pay attention to the paths you set.
    So if it goes under say Poser character library the look for the DSON Conversions folder it should be under there.
    Or if you chose props look for the DSON Conversions folder there.
    781 x 547 - 142K
    614 x 766 - 175K
    Hold it you may have to save it as a DUF file first or it won't work !
    if that's the case do this first as Figure/Prop Assests see screenshot.
    save in the same dir and fill out box
    592 x 468 - 106K
    614 x 766 - 195K
    thank you so much man....there is a problem though...i cant find it in my libraries...anywhere... someone mentioned that because its an old version it wont open to latest studio? is that correct?
    but thank you so much for the detailed explanation!!!i really appreciate it!
    It's 2am here I'm just off to bed I'm sure some of the other guys will be able to talk you through. But you have to at least save it in the new format or there's no chance. I'll check in tomorrow to see how you went. If worse comes to worse I'll do a Utube video.
    Cheers.
    PS I udated the last post !
    No that's not correct. It opens just fine in DS-4.6. The main loader file is in the old binary format that DS used to use (before everything went DUFfy and DSFfy) -- roughly equivalent to the old Word ".doc" format, before everything went ".docx".
    It's under "Props" in your "DAZ Studio Formats" folder (ie it does NOT appear under the Poser Formats folder tree). Remember, you'll need to have both "DAZ Studio formats" as well as the "Poser formats" folders mapped in the Content Directory Manager. Here is the process I used:
    (1) installed it via DIM;
    (2) right-click on it in the Installed tab in DIM, to check the "Show Included Files" -- this showed me that the main loader file was installed under "/Props/Temple of Mars/Temple of Mars.daz" -- under the "/Runtime/" folder there were only textures. This is reasonable, given that the file will not be loaded directly under Poser;
    (3) loaded it in DS-4.6. Note that the file is found under the "DAZ Studio Formats" section, NOT the "Poser Formats" section, under a "Props" folder;
    (4) select item in the scene, File -> Export..., Save as Type "Wavefront Object (*.obj)"... just used the default export options, ensuring the "To:" is set to Poser (because that will affect the visible size when loaded). The one thing that could be adjusted for convenience on the screenshot is to change "Original Maps" to "Collect Maps". That will make a copy of all the associated textures into a folder right beside the generated .OBJ (instead of the way it is at the moment, which uses the original textures - that Poser doesn't find by default).
    (5) in Poser, File -> Import -> Wavefront .OBJ, ... again, default import options (although you're probably better at this section), select exported file, and voila! \(^_^)/
    632 x 658 - 40K
    1024 x 1024 - 599K
    1024 x 1024 - 70K
  • DimeolasDimeolas Posts: 192
    unfortunately as I have found on sevral occasons the info for products refrencing compatability and requirements is many times wrong or incomplete.
    thank you so much everybody! you ve been very helpful....problem solved!
    also a big thanks to Cristina Galloway from support who really took this serious...
    thanks guys and girls!
