Tongue materials - where to find and adjust
endlessloving
Hi there,
I am trying to find the material/surface settings for the tongue in Daz but I can only find materials for the mouth and teeth.
Can anybody please tell me where to find these settings?
Post edited by endlessloving on
Which figure?
The mouth material is the whole mouth with the exception of the teeth. If you need to adjust only the tongue, you'll need photoshop or GIMP. As I recall this is true for all genesis figures.
That's good to know!
Will look at the textures.
VYK Zuri
So Genesis 8 Female is the figure.
That's correct. I am not yet used to the terminology!
...just a side note, Genesis1 has mouth surfaces separated in gums, inner mouth, teeth and tongue...
A quick & small sidenote, but hopefully it can help you a bit...
Basically every humanoid figure within Daz Studio is based on a "root figure" so to speak; Genesis. Genesis has 5 generations in total (see also my attachment): Genesis (or 'Genesis 1' I suppose) is a unisex base figure (it has no gender but can be morphed into male, female or whatever other creature). Then we have Genesis 2, 3, 8 and 8.1 where the latter generations make a clear seperation between male and female genders.
If you're unsure about a figure you're working with then check the top of the "Parameters" pane; it will tell you exactly what kind of figure you're working with.
Hope this cleared a few things up for you while not making things too complex ;)
There's that memory of mine not being quite accurate again. LOL
