Fit Control for Genesis 8 Male - Says select genesis 3 male
Advint
Recently when going to use Fit Control for a Genesis 8 Male figure it told me to instead select a genesis 3 male. It also didn't show up in smart content for the genesis 8 male I had selected. I was using a basic figure, so it shouldn't be a figure specific issue. As well I was using hte 4.15 beta at the time, but intend to also test it in version 4.15 public. I will update this post at that time.
? are you using Fit Control for Genesis 8? or Fit Control for Genesis 3?
I have the bundle. But even when I go to content library it didn't work correctly. I still have yet to test it again. And I shall as soon as this simulation is done.
I just tested it in Studio 4.15 public, and it worked. It could simply be as you said that I was selecting the wrong one. But if I recall correctly the Genesis 3 fit control was showing up for genesis 8 in smart content. While the genesis 8 fit control doesn't even show up in smart content (easy fix).
Which bundle?
Note, that "Fit Control Add-On for Genesis 3 and 8 Bundle" is an add-on to "Fit Control for Genesis 3/8 Female/Male" (4 different products) not an add-on for Genesis 3/8 Female/Male figures.
