Victoria 8.1 FBM not symmetric
Hey there,
Maybe you already noticed GF 8_1 nose tip isn't symmetric...
With Victoria it gets much worse, on the breasts, back, calves, etc.
See the attached screenshots for reference, with the original and mirrored meshes.
Please DAZ, fix the bugs, it's a nightmare to morph non-symmetrical meshes! ;)
980 x 1254 - 1M
1150 x 1279 - 1M
2154 x 1356 - 3M
1024 x 1422 - 1M
944 x 967 - 798K
1030 x 1286 - 822K
1825 x 1629 - 2M
  • DireWorksDireWorks Posts: 135
    quickly tested even i was scheptic about it g8.1 looks fine
    test metod on a duplicate x:-100% in ds wireframe view
    check your morphs, maybe you have an active asymmetric morph saved as asset not zeroed or hidden
  • meipemeipe Posts: 108
    I can see even in DZ wireframe, just with the default figure and no extra morph loaded.
    edited January 2021
    Two first images from Victoria. Third one is the default GF8_1 nose tip
    1571 x 1572 - 970K
    706 x 708 - 185K
    573 x 744 - 257K
    Post edited by meipe on
  • MasterstrokeMasterstroke Posts: 2,512
    edited January 2021
    meipe said:
    Hey there,
    Victoria does not need to be symetrical, she is a character based on Genesis 8 Female.
    Genesis 8 Female is the base figure, which has to be symetrical. So if you are creating morphs, clothes, hair, geo grafts or any other add ons, use the Genesis 8 Female base, not Victoria 8.
    Post edited by Masterstroke on
  • Seven193Seven193 Posts: 1,156
    edited January 2021
    G8F is not 'perfectly' symmetrical either, at least down to a tolerance of 0.001f.  There are several mismatches.
    I think since Genesis 8 was based on a the previous generation, they didn't mirror and copy the geometry to make it perfectly symmetrical.
    In fact, the last 'perfectly' symmetrical generation was Genesis 2.  Genesis 3 also has mismatches, but not as bad as Genesis 8.  Symmetrical error has been drifting farther since Genesis 3.
    Post edited by Seven193 on
    If you create geografts, vicky morph will be transfered to the geograft. And if the result isn't good, you have to edit the morph to correct it. With such an asymmetric geometry you can say goobye to mirroring your sculting tool.
    pardon me, now i see, about the nose tip i was thinking it was on Y axis on front view, thights zone also its clearly visible
    no errors on my few g8 geografts for the moment
  • takezo_3001takezo_3001 Posts: 2,044
    edited February 2021
    While this new venture into her asymmetrical morph is great for realism, it is a nightmare for modelers that want to specifically model victoria's 8.1 limbs as the GOZ swap feature in the import dialogue is rendered useless as the right/left side of her body doesn't match!
    Post edited by takezo_3001 on
