Default Button
Is it just me, or is anyone else having trouble with the Default button on the Render screen (directly under the Render button)? It used to work for me, but not anymore. When I want to set it back to the default render settings, nothing happens. It just remains whatever settings have been changed. Is this a quirk of the latest DS version or something I'm doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 112,078
    edited January 2021
    It's working as expected for me, which settings are you changing?
    Ah, it doesn't work for the environment and Tone Mapping settings, the ones that are now on the new singleton nodes. For those, selecting the nodes and using Edit>Object>Restore>Restore Selected Item(s) works. I don't know if this is how it should work, or if it is intended that the defaults button should also affect them (I'd find the latter more natural, for what it's worth).
  • melaniemelanie Posts: 807
    Thanks, Richard. I didn't know that. The Default button always affected those things before. Maybe this is something new they've changed. I'll give your suggestion a try.
