m4 hair and build
naioranaiora Posts: 28
hi alll
anyone know how to:
build m4 for dwarf build (short and large)
and a hair as in image
thanks
Neva
    There is this for M4 and V4 : http://www.daz3d.com/the-marvelous-morphs
    You would also need to have M4 Morphs++. The hair I cannot help with, but someone else may know.
  • naioranaiora Posts: 28
    i saw morph++ and im wirking with it^^
    hair is most great problem :(
    thanks for reply :D
    Firstly, the area is wrong. This kind of help goes to The Commons.
    Secondly, are you trying to recreate Gotrek or what? Any mohawk will work. Making a dwarf on Genesis is easier. Dariofish has a fantastic set of morphs complete with beards and textures.
    first sorry i was viewing that many area and this seemed right :(
    second
    where? i searched all kind of air and beard like dwarf of warhamme :S:S can you post link?
    edited September 2014
    New User Forum is here to help New Users, regardless of what the query is, so you are posting in the right place.
    Would this hair be of any use http://www.daz3d.com/mohawk-hair It is an M4 hair. the Dariofish ones are for Genesis; which wouldn't help you, if you are using M4
    Post edited by Chohole on
  • kaotkblisskaotkbliss Posts: 2,918
    HAH another warhammer player... it's been too long for me though :(
    anyways, if the Mohawk that chohole linked to doesn't have a parameter for the height of the Mohawk, then you should at least be able to force the height by scaling it so either way, it should work for you :)
    ill try this evening i crushing head for to create a video with dwarf trollslayer^^
    I originally found this thread here: http://www.daz3d.com/forums/categories/506/. It must have been moved, but the question is: why are you set up on using M4? Genesis is more versatile if you need fantasy characters. Check out the Freepository as well, there is a free mohawk hair.
    i'm using m4 because most of package i have are for M4 :D
    genesis is not 100% compatible with m4 packages^^
    for free repositories you mean freebies in shop ?
    It is called 'General Freepository' and is a forum on this site.
    http://www.daz3d.com/forums/categories/41/
    You will need to do a search on the free hair items I think, but there is a few Mohawk styles, maybe even do a search on the whole forum for 'Mohawk'.
    AdamThwaites has a prop of a mohawk cut here: http://www.renderosity.com/mod/freestuff/?item_id=38682.
  • Tramp GraphicsTramp Graphics Posts: 2,422
    You should know that all of your M4 texture sets will work on Genesis, as will virtually all of his conforming clothing sets (only boots and shoes may or may not give you some trouble). M4 and V4 morphs can be converted using Genesis Generation X (now X2), so you really can use pretty much all of your M4 content on Genesis with only a few exceptions.
