GENESIS/G2 SHAPING CONTROL?
Viper016Viper016 Posts: 159
edited September 2014 in The Commons
Okay, so I got the Minotaur for genesis and he has hooves BUT I want genesis to have human feet with the rest minotaur like.
like do I need to have something extra for both Genesis and Genesis 2 just to have selective morphs/shapes like M4/V4 had?
Is there any simple built-in way to get make a limb have selective morphing/shaping? LIKE MICHAEL 4/VICTORIA 4 had?
or did the amazing genesis/g2 only can go so far depending on what the vendor has supplied for the user?
I even checked "Show Hidden" and all shaping/morphs do not show even tho they are obviously deforming the selected part...
Thanks for taking out your time to read this!
~Sev
Post edited by Viper016 on
  • Richard HaseltineRichard Haseltine Posts: 112,067
    With TriAx figures the mesh belongs to the whole figure, it isn't split across bones and so you can't apply a morph selectively if it isn't set up that way. The only way around that is to use a modeller to create a new morph - Blender has the needed functions though I've not tried it.
    The Hooves are a separate dial under Legs / Universal / Fantasy SciFi.
  • Viper016Viper016 Posts: 159
    It's not there, just RawCat Legs and no Valandar Hooves :(
  • XenomorphineXenomorphine Posts: 2,421
    It should be possible to duplicate the Genesis figure (the option is under one of the menus), as it's replicated in exactly the same pose (use 'with nodes' to also duplicate anything parented to the figure, including hair, clothes and any associated movement or shaping morphs already applied to them). Then apply the morph to one and not the other. All you should then have to do is hide the feet of the creature and hide everything else from the still-human Genesis.
    The only problem might be in the form of the skin texures not suiting one another, but it should work at range or with clever use of lighting. Especially if using footwear!
    Not ideal, but it's a compromise which should hopefully allow you to do the basics.
    Post edited by Xenomorphine on
    The morph name is "Raw_Minohoof_Frk" or "Raw_Minohoof_Gen" depending whether or not you use the Freak4-based body morph. And you say "shaping control" — are you looking in the Shaping Tab or the Parameters Tab? The Shaping tab doesn't show every body shape, but the Parameters tab does.
    My bad, gotta be more clear lol
    I'm using Valadar's Minotaur for Genesis not RawArt's Tuaran mino thing lol
  • Scott LivingstonScott Livingston Posts: 4,352
    I don't know that there's a way to do that with the Minotaur, unless you want to create your own morph. Here's a thread on splitting head and body morphs that might be of some use (presumably one could split off a leg morph instead of a head morph using the same method)...I haven't attempted this myself.
