Lost Newbee 2
Many thanks for the support everybody. The Wilmap source was quite helpful. The problem now is the content manager simply will not respond. I tried to use the "user" log in, but the program just vanishes. When I try to use my Daz user name and password the program won't recognize them. Is there by any chance some sort of "backdoor" method you can get vendor info into the Daz library without using the content manager.? If not, Poser's looking better all the time.
Mungwort
  • kaotkblisskaotkbliss Posts: 2,918
    I know when I first installed the DIM and tried to log on, I had to keep adding a new profile and logging in (same username and pass as for the forums) and would go back and forth between the original I setup and the new one I created, then deleted, then readded, etc. until the DIM finally logged in. Once that happened, I've not had a bit of trouble since.
    You can still get your items manually if you go to "My Account" at the top of these forums (or any DAZ page) then lick on the link for "My Library"
    All items that you've bought are listed there with a DIM link as well as a manual download link so you can save and extract the files to your hard drive without the DIM.
