Normal maps control
RAMWolffRAMWolff Posts: 10,393
edited September 2014 in The Commons
Hi,
IIRC when DAZ first added in Normal Maps they were static, meaning one could use the tiling options but the maps stayed static. Now they tile along with the rest. So making shaders but having a map that I need to pop details say on the main obj is gone now. Are there tools I don't know about to control tiling for each individual map like Bump, Displacement and Normal Maps? This would be very helpful right about now. If not I think in DS 5 DAZ should add in extra drop downs for each of these areas (including Reflection and Refraction too) to have "Tiled" "No Tiling" .... Also, Normal Map strength min and max would be appreciated!
Please DAZ.
Thanks!
Post edited by RAMWolff on
    I agree. With the reality plugin you can set the tiling for the normal map regardless of what is set for the diffuse map.
  • SimonJMSimonJM Posts: 6,102
    Don't forget Opacity! Total pain to knock up a custom Opacity Mpap, add it to a ground plane amd have ... a sudden attack of the moles as enough hole to 'fill the Albert Hall' appear ;)
  • BejaymacBejaymac Posts: 2,010
    Try learning how to use the ShaderMixer rather than the junk that comes with DS.
  • RAMWolffRAMWolff Posts: 10,393
    Yea, I don't get plugging in bricks and what not. Too complicated for my brain. lol
  • almahiedraalmahiedra Posts: 1,374
    Possibly the only thing that you need is set a new tiler brick connected in s and t parameters of image brick and next change labels of s and t in tiler brick.
    Post edited by almahiedra on
    Is it you need? Or I going worse with english and I didn't understand that you want.
    http://www.daz3d.com/tiler-shader-for-daz-studio
    610 x 801 - 86K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,696
    you can use shadermixer and plug a brick in to tile it I think
