Victoria 8.1 Log WARNING
painterhoyapainterhoya Posts: 9
edited January 2021 in Daz Studio Discussion
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Wink.dsf#facs_ctrl_Wink?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Wink.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Triumph.dsf#facs_ctrl_Triumph?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Triumph.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Scream.dsf#facs_ctrl_Scream?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Scream.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Sad.dsf#facs_ctrl_Sad?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Sad.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Pouty.dsf#facs_ctrl_Pouty?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Pouty.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Pain.dsf#facs_ctrl_Pain?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Pain.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Ill.dsf#facs_ctrl_Ill?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Ill.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Happy.dsf#facs_ctrl_Happy?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Happy.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Glare.dsf#facs_ctrl_Glare?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Glare.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Fierce.dsf#facs_ctrl_Fierce?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Fierce.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Fear.dsf#facs_ctrl_Fear?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Fear.dsf
WARNING:\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8_1Female:/data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_ctrl_Disgust.dsf#facs_ctrl_Disgust?value in file : /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Victoria 8_1/facs_Victoria8_1_ctrl_Disgust.dsf
I have purchased Victoria 8.1.
Before installing Victoria 8.1, there was no error log when importing "Genesis 8.1" from "Daz studio".
However, after installing Victoria 8.1, a warning message is displayed
facs_ctrl_Wink.dsf
acs_ctrl_Scream.dsf
facs_ctrl_Sad.dsf
facs_ctrl_Pouty.dsf
facs_ctrl_Pain.dsf
facs_ctrl_Ill.dsf
facs_ctrl_Happy.dsf
facs_ctrl_Glare.dsf
facs_ctrl_Fear.dsf
There is no above file in the library folder.
What should I buy?
Post edited by painterhoya on
  • charlescharles Posts: 866
    edited January 2021
    Try downloading and reinstalling the G8.1 and default resources. Is it coming up with an annoying box when you load or is this just contained to the logs? I seem to have some thousand lines of such warnings but everything works fine
    These are really just links to products looking for other products that you may not have. ERRORS and DUPLICATES are what you should really be concerned with.
    Post edited by charles on
    I reinstalled G8.1 and basic resources today and have the same problem
  • nemesis10nemesis10 Posts: 4,023
    "I reinstalled G8.1 and basic resources today and have the same problem".....
    That is Daz Studio 14.5, Genesis 8 essentials, and Daz Resources so all 3 things, correct?
  • MasterstrokeMasterstroke Posts: 2,507
    Can you load G8, G8.1 or Victoria 8.1 into your scene?
    If not, how do you try to load it into your scene?
    yes i installed  "Default DAZ Resources for 4.15"  and "genesis 8 Female Starter"  and "Victoria 8.1"
  • painterhoyapainterhoya Posts: 9
    edited January 2021
    can into scene its a work. but error log when importing "Genesis 8.1" from "Daz studio"
    and There is "facs_ctrl_Wink.dsf" facial expression
  • How are you installing?
    Are those part of "Genesis 8 Female Expressions"?
    Ah, okay. I thought your problem and my problem might be somehow connected, for I cannot load G8 Females by just clicking on them. I am getting a file does not exist message. Unlike, when I drag and drop G8 Females into my editor it does work.
    ...weird
  • Have you installed the Genesis 8.1 starter essentials?  I think that comes with a DAZ Studio 4.15 update.  You need it to use Victoria 8.1.
    edited January 2021
    there anything else I need to install??
    1179 x 914 - 34K
  • I purchased 8.1 and have the same or similar problem. I can load all other versions of Genesis/Victoria by clicking image with no problem.
    With 8.1 I get the message:
    The following files could not be found:
    data/daz 3d/genesis 8/female 8_1/genesis8_1female.dsf
    data/daz 3d/genesis 8/female 8_1/morphs/daz 3d/mouth realism/phmmouthrealism8_1_hd_div4.dsf
    data/daz 3d/genesis 8/female 8_1/uv sets/daz 3d/base/base 8.1 female.dsf
    runtime/textures/daz/characters/genesis8_1/femalebase/g8_1eyeirisdepthnormal_1007.tif
    runtime/textures/daz/characters/genesis8_1/femalebase/g8_1mouth_nm_1006.tif
    I deleted 8.1 files, downloaded again and re-installed, still get same issue.
    You have installed the updated Genesis 8 Starter Essentials and the updated Default Resouces?
    I gather some people have had difficulties and have had success by deinstalling the G8 starter esssentials and Default resources, then reinstalling rather than overwriting them.
    edited January 2021
    The same problem occurs when installing for the first time without overwriting and nothing.
    Did you have a "facs_ctrl_Wink.dsf" file?
    Don't those belong to "Genesis 8 Female Expressions"?
    edited January 2021
    The facial expressions in v8.1 are no longer compatible with v8.
    Have you checked that the expressions are not updated to include 8.1?
    https://www.daz3d.com/genesis-8-female-expressions
    edited January 2021
    oh thanks!
    I didn't have the product of "Genesis 8 Female Expressions"
    I have bought it now. Now the same problem does not arise. Thank you.
    Thanks! That fixed it!
  • 3Don3Don Posts: 690
    I had some missing file notices when I tried to load G8.1. Some of the same files as listed in above posts. Jack directed me to this thread.
    "Have you installed the Genesis 8.1 starter essentials?  I think that comes with a DAZ Studio 4.15 update.  You need it to use Victoria 8.1."
    I am stuck on DS 4.9 for now. Does that mean I cannot load or use Genesis 8.1?
    DS 4.9 is quite old...
    You may be able to load Genesis 8.1 on it, but you will not get any Genesis 8 characters/morphs and/or expressions to load for it and you will probably have problems fitting items to it and using whatever scripts with it.
    The new shader also needs 4.15
