How to apply texture on genesis 2 female genital?
stormqq
I added it to my genesis 2 model but it's just grey how to apply texture on it?
and I have another question, how to blend textures in daz. let's say there are two texture, genital and body but due to colour different the seam is visible around the genital so how to blend it and remove it?
The easiest way is to simply copy the hip material from Genesis onto the genitals. They share identical mapping, so you can use the same texture across the whole figure. Not sure why you'd want to use a different skin for the genitals, but there's no easy way to blend them. You can't make them translucent, since its a geograft which replaces part of the actual geometry.
Your only real solution if you need to use different textures is to render two different figures, one using the same skin as normal, one with the mixed textures, and blend them together in Photoshop or Gimp
done thanks, I selected the genital and applied a texture
