Looking for a bendy bar (morphing primitive)
handofbobb_2f0555398e
Hey all- does anyone know where I can find a rectangular bar/beam that can bend into an arc?
I'e got the "Everyday Morphing Primitives", but the only piece in there that can bend is a tube, and none of the semi-circular pieces let you change the degree of their arc.
(slightly updated the pic to be more accurate, but bear in mind it’s a crappy 2 minute MS paint pic.)
800 x 600 - 28K
Post edited by handofbobb_2f0555398e on
If its a morphing DS prop, Ill make you one tonight if you like, drop me a pm with your email address along with exactly what you need, eg Do you need the edges bevelled or sharp?
its only a 5 min job to make it though.
I had this issue a while ago. Look for "tentacle" props. Weird, I know. But throw on metallic shaders and keep them straight and some of the lower poly ones look like poles. I found one on shareCG that fit the bill perfectly. There we morphs that made it completely flat and smooth. The only downside is that it's hollow and the end has no cap so it's like a big straw.
Be careful, due to the nature of the search terms some results are NSFW, as you can imagine. ShareCG should be safe I think.
yeah, I have several morphing tentacles, but they are all cylindrical, I'm looking for something with a square cross-section.
I know I have something like that in my runtime, but can't remember where it came from. It's a square cross section bar with bends. I'll check again.
