Missing file data/daz 3d/built-in content/daz iray pbrskin/pbrskin.dsf
I seem to be missing this file when i try to open Victoria8.1.  Could anyone tell me what I need to download to get this file?
  • LeanaLeana Posts: 13,554
    That's the new skin shader. You need to install the latest version of DS Default resources to get it.
    Are you using DS 4.15 and have you updated the default resources for it (IM00013176-42_DefaultResourcesforDAZStudio415.zip)
  • Ah thanks, I am using 4.15 but not sure if I updated that.
  • Updated the default resources and all working fine now. many thanks.
  • ZarquenZarquen Posts: 23
    edited January 2021
    ok, but.... where do i find those default resources?
    PS: I DONT use any daz-central nor any auto installer.. only manual installation.
    Post edited by Zarquen on
    Go to your "My Account\Product Library" here at DAZ site and search for "Studio 4.X"
    The "IM00013176-42_DefaultResourcesforDAZStudio415.zip" can be found amongst the downloadable Studio 4.15 files and if you scroll down, you will find links to the Genesis 8 Starter Essentials
  • And what if searching for "Studio 4.X" or even "Studio 4.15" both come up blank, as in nothing there, at all?  I ran into the same problem with the OP.  Found out it was the Default Resources file so I looked at the "Installed" tab in DIM & noticed it wasn't updated.  I uninstalled it which moved it to the "Ready to Install" tab.  Then I deleted it from the "Ready to Install" tab expecting it to get moved to the "Ready to Download" tab as an updated file.  Flat out disappeared, nowhere to be found.  Also found out that my normal (general release) daz studio hadn't had any DIM updates since 4.12 which would explain the lack of updates for the Default Resources but definitely doesn't explain why no updates to the general release daz for that long.  I've gotten all (I think) updates for the beta and am at 4.15.0.2 but not the general release.  When I found this out I did the same procedure with my 4.12 general release (dumb idea) and now that is completely gone and absolutely nothing in my product library on the site so no way at all to download daz general release or default resources.  Everything else is up to date (Starter essentials, dynamic cloth, photoshop bridge, etc.  I submitted a ticket 2 days ago about this but haven't heard back at all and now it's the weekend so I'm pretty sure I won't hear back in the next couple days at least.
  • VoidOVoidO Posts: 47
    SOLVED (for me). I simply could not find the Daz Studio 4.x product in my account/products. I was always going through the public beta, because that's what I was using. I added the non-beta / real Daz Studio 4.15 and it downloaded the missing pbr files. Here is where you can add this product to your cart: https://www.daz3d.com/daz-studio-4-pro
  • I am getting the message
    The files listed below cannot be found:
    /data/Daz 3D/Built-in Content/Daz Iray PBRSkin/PBRSkin.dsf
    when I try to load G9 or any G9 actor. I have tried to reinstall DS but that did not work. I have tried to find the Daz Iray PBRSkin in Shader Presets, assuming this would be a default resource, but I could not find that PBRSkin anywhere.
    Any suggestion?
    Any suggestion?.
     That file is part of Daz Studio default resources pack, not the application.
  • Thanks Leana, I got it.
