Boudoir Secrets on Gen2 females
DopplerShiftDopplerShift Posts: 0
edited September 2014 in New Users
Boudoir Secrets on Gen2 females...
What do I need in order to use this on Victoria 6 and other Genesis 2 females?
http://www.daz3d.com/boudoir-secrets
Do I simply need this?
http://www.daz3d.com/victoria-4-for-genesis-2-female
What about these Boudoir Whispers products? What do I need to use these?
http://www.daz3d.com/boudoir-whispers-for-v4
http://www.daz3d.com/boudoir-whispers-v4-unimesh-fits
http://www.daz3d.com/sweet-secrets-for-boudoir-whispers
Compatibility for products is so confusing. I purchased Boudoir Secrets and some textures hoping that they would just auto-fit but they wouldn't even load. I'm guessing I need V4 for genesis 2. Am I correct?
But I'm confused by this tutorial which says I need "Basicwear for V4 Unimesh" and that says I need "Victoria 4.2 Morphs". I'm bewildered by the rabbit hole of compatibility charts.
http://www.daz3d.com/using-auto-fit-victoria-4-to-genesis-2-female
Post edited by DopplerShift on
  • Richard HaseltineRichard Haseltine Posts: 111,820
    The products may not be required, but if they are it's because they are used in the tutorial - you don't need them for converting V4 clothes in general to Genesis 2 Female, you just need the V4 for G2F product that you link (though the results with the dressing gown may not be satisfactory without refinement, and the high-heeled shoes will certainly need work).
  • mark128mark128 Posts: 1,033
    You definitely need Victoria 4 for Genesis 2 Female in order to auto-ft V4 clothing to G2F.
    The tutorial uses Basicwear for V4 Unimesh, which I believe is free. Basicwear for V4 Unimesh says it requires Morphs++, but I believe that is only true if you are going to use it on V4. I don't think Morphs++ is required to auto fit it to G2F.
    I don't have any of those lingerie products for V4, so I cannot say how well they auto fit. I would expect they would work fairly well.
  • DopplerShiftDopplerShift Posts: 0
    OK. Thanks for the help.
    Hmmm... I can't seem to get this to work.
    I installed V4 for Genesis 2 but the Boudoir Secrets and Whispers clothing still will not load into my scene.
    Also, V4 does not show up in my library for me to load into the scene. It is only in the shaping dialog.
    On top of it, when I install the Autofit tutorial, it doesn't show up in my library either, so I can't even follow that.
    Can somebody help me?
    Where are you trying to load these items from? They are in Poser Format (CR2) amd you should find them in Poser Formats > My DAZ 3D Library > Figures. You may be trying to load materials for the DAZ Studio Formats area.
    When you load the clothing, select Genesis 2 F in the Scene pane, Autofit should pop up, and ask what figure the clothing was originally made for, select V4, and it should work
    All that you have bought, is a 'shape' for G2F which 'looks like' V4, it is not the V4 figure itself.
    On top of it, when I install the Autofit tutorial, it doesn’t show up in my library either, so I can’t even follow that. Go to Help > Home, and select Interactive Tutorials from there. You should then see a tab at the bottom right of the screen which says 'Select a Lesson'.
    ...you should find them in Poser Formats > My DAZ 3D Library > Figures
    This was the part I was missing. Thanks!
