V8.1 Renders White in iRay
As the title says, V8.1 is rendering white in iRay. Does 8.1 actually require 4.15 to work properly? I've downloaded the updated 4.15 default resource pack. I'm using 4.12 as I've seen too many problems with 4.15.
V8.1 renders fine with V8 texture applied.
    To use the new shader, yes. With the previous shader it should be ok.
  • Unfortunately the new shader requires features that were added in DS 4.14.1.x, now DS 4.15.x.x, so it won't work in 4.12.x.x
  • furiousstugfuriousstug Posts: 231
    edited January 2021
    Well, shoot. No 8.1 for me...
    Can 4.15 be a separate installation so either 4.12 or 4.15 can be used?
    Post edited by furiousstug on
    Beta versions are separate installs from release versions but they can only be installed with DIM (and possibly with Central but I wont touch that with a 39.5 foot pole).
  • how do you update the newer verson
    Not with Central
  • Seven193Seven193 Posts: 1,156
    edited January 2021
    I'm having the same problems, even with DS 4.15 installed.  The skin isn't completely white, but super bright.
    When I load Genesis 8.1 Female, the default skin shader applied is "Iray Uber".
    So, I scroll down to Shader Presets, and click on "Daz Iray PBRSkin".
    After doing that, I get a super bright skin, and the eyeballs turn white.
    Also reinstalled these two files:
    IM00042071-01_Genesis8FemaleStarterEssentials.zip
    IM00013176-42_DefaultResourcesforDAZStudio415.zip
    Does G8.1 come with base material skin presets using "Daz PBRSkin" ?  Because I don't see them.  There's an Iray base material directory, but that's for the "Iray Uber" shader.
    Post edited by Seven193 on
  • Victoria 8.1 uses the new shader.
    Ok, thanks.
    So, generally speaking, if I wanted to convert from "Iray Uber" to "Daz PBRSkin" or vice versa, another step is needed to make adjustments?
