Installation?
MynyoriMynyori Posts: 86
I'm trying to install 3D Bridge for Photoshop. I found the instructions for it under the help desk and came upon this section:
3D Bridge Plugin INSTALLATION
The 3D Bridge plugin installs files for both DAZ 3D and CS (Photoshop). The installer will already be able to figure out the correct path for the plugin files for use in DAZ Studio. However, during the installation, you will be asked the installation path for the file for Photoshop (CS). You should browse to and select the correct folder called 'plugins.'
I've gone through the Install Manager>Settings>Applications and changed the path to plug-ins. I've also changed it to automate. Each time, I can't get PS CS6 to register it. Am I putting it under the right folder and/or should I have changed Manager>Settings>Installation path instead?
    Can you post a screenshot of the DAZ Install Manager > Settings > Applications tab?
  • MynyoriMynyori Posts: 86
    Here it is.
    784 x 619 - 52K
    Don't put in the path to the Plug-Ins subfolder, stop 2 folders up at the folder which has the actual application.
    That did it. Thanks.
