Editing morph vertex question
Hi,
I'm trying to remove the head from the gyn-02 full bodysuit smooth morph so it only affects the body with no success. I tryed following this youtube video: https://www.youtube.com/watch?v=XuQwnTd4Fok (DAZ Studio: Fixing/Editing Morphs - How to Remove Unwanted Vertices From Morphs) so here are the morph selected vertices:
then I select the head vertices and remove the from the morph with the morph editing -> clear selected deltas from favorite
If I then again, make the use the option select morph vertices, there is no head vertices.
Now if apply the morph 100%, I can see the head vertices still affected. Any one can help me understand what am I doing wrong?
Thanks for any help :)
Post edited by Chohole on
Is it an HD morph? If so you will not be able to edit its effect on the virtual vertices created by SubD - set the mesh resolution to Base in the parameters pane and, depending on how it works, you may find the morph is limited as you wish (but of coruse that's not useful).
I think is and HD morph, I mean to look right I have to set the my gen8 resolution to HD maybe this is the problem.
If I understand what you said, if its an HD morph, this method will not work?, is there a way to do this?
Thanks for your time
No, if it is an HD morph it isn't possible to do this kind of editing.
I understand, that's a bummer. Is there a way to contact the maker of the outfit (he is a seller here at daz)?, maybe he can help me
If they aren't active on the forums all you could do is open a support ticket.
Thanks a lot for your help Richard. I wrote to the author asking for help, maybe he can help me with this.
Regards
