Trouble saving a custom expression
Hello,
I have a dial spun character that I am trying to save an expression for. The expression makes use of some of the standard G8F expression morphs as well as one additional morph that was made for the P3D character Melanie. It is a smile morph. The morph that I have created mainly uses the G8F Open Smile Full Face HD morph (dialed back to 70%) combined with the P3D Melanie Special Smile HD morph at 30% along with a couple of other small expression tweaks. However, when I try to save the expression as a pose preset, the Melanie morph is not captured.
When I do the Pose Preset save, I make sure to select Pose Controls->Head as well as Hidden->Pose Controls->Head in the Pose Preset Save Options Dialogue. I have tried this several times with no success. It should be noted that in the Parameters Tab morph listing, under Pose Controls->Expressions the Melanie Smile morph only displays when the Main Character is selected in the Scene Tab and not just the head. This is actually the case for several expression morphs that I have and I have not had any issue creating and saving custom expressions using them.
The thing that is different though, is that when I expand the Pose Contol properties in the Pose Preset Save Options Dialogue box, I can't find the P3D Melanie Special Smile HD morph but I can see all of the other custom morphs that various PA's have made.
Does anyone have any idea as to why I can neither find the morph or save the setting for the Melanie smile morph when I try to save it as a Pose Preset?
Thanks in advance for any replies.
nabob21
  • Going by the product page: 1 Custom HD Smile Apply/REM {I don't own this yet}
    Apply the HD Smile. When ready then save as a Shape Preset. Uncheck Genesis 8F, then right-click and select the option to check only all modified. Carefully open the tree to check if there is anything else you want unchecked. Whatever morphs were used to make the HD Smile morph should have been automatically selected by the dialog.
  • nabob21nabob21 Posts: 1,058
    Thanks Catherine3678ab. I'll give that a try.
