GoZ Send only Selected Items
TimingisEverythingTimingisEverything Posts: 112
edited September 2014 in Daz Studio Discussion
I really like the GoZ Plugin, but I have a question...
When sending Figures that have Things Conformed, Is there a way to Send only that Figure only, and not the conformed items with it?
Post edited by TimingisEverything on
  • Cris PalominoCris Palomino Posts: 13,051
    Everything in the scent will GoZ over, however, they will be separate subtools. You could delete them or you can hide them. In many cases, for instance doing a morph for a shirt on G2M, you would want the shirt and the figure to be in zbrush so you can see what to fix while it's on the figure.
  • SloshSlosh Posts: 2,391
    Actually, everything in the scene won't be sent automatically. Only selected items and anything parented to them. In the case of Genesis 2, most clothing and hair has been saved parented to the figure, so they go to ZBrush along with her. If you don't want extra items to go, just make sure they are not parented when you click GoZ.
    Oh, I did try to unparent hair from the figure and even hide it and it still appeared in GoZ, so I'll try testing it again based on your experience with this, Slosh. Thanks for the info.
    I spoke too soon, or not correctly, or both. The parenting is not what determines what goes with GoZ... it's the conforming. Anything not conformed to the figure will stay behind in DAZ Studio, such as other characters or props or environments. That being said, you can select any child items, such as hair or a shirt, and send it by itself to ZBrush via GoZ without the other items following it.
