DAZ Install Manager (has encountered a fatal error, and must close)
Like most people, I'm brand new to everything 3D. I was told Daz3D was a good starting program to use, so I wanted to give it a shot.
I downloaded the Daz Install Manager from the website after creating my account, and it installed to C:\Program Files (x86)\DAZ 3D\DAZ3DIM1.
I start Daz Install Manager and login with my account, where I'm now prompted with things ready to download. I select just the first option DAZ Studio 4.6 (Win 64-bit) because I'm using Windows 7 64 bit version. I click the Start Queue Button in the bottom left, and immediately after, it crashes with the attached screen.
I saved the crash log (zip file), but I am not technical enough to understand what the issue is.
I tried using DAZ Install Manager again, and unchecked Install After Download just to see if it could download anything without installing and the same issue occurs.
Any recommendations on what I'm doing wrong?
511 x 191 - 42K
    Could you click the More button and save the error report, and then use the Help > Contact Us link at the top of the forum to submit a report to Technical Support. You can attach the zip file to the report.
  • monkeygovernormonkeygovernor Posts: 0
    Trouble Ticket created (Request #176368).
    Thanks, I can't wait to get started. Been trying to figure this out for a couple of nights.
  • I'm new and this is an very common issue; and I'm actually disappointed that there is no solution to it besides contacting support.
  • MarieMarie Posts: 57
    edited November 2022
    hi did you get this sorted since I download new install libary its given  me this message & I deleted old daz :C
    Are you sure it is the same? This is a very old thread.
  • I also have the same problem
    zip
    zip
    DAZStudio_error_report_250612-004543.zip
    44K
  • Richard HaseltineRichard Haseltine Posts: 111,382
    That is a Daz Studio crash report, this thread - which is over ten years old - was about an Install Manager crash. Please give details of what is actually happening for you, and your system details..
  • kenmokenmo Posts: 1,235
    My DAZ Install Manager is not giving the option to select an install path as it always did in the past. Never had this error before. What gives?
    Do you have more than one path set?
