Camera Question?
beachlegsbeachlegs Posts: 531
I have loaded a scene in poser9 (The streets of the Mediterranean) and I am using the camera view-(Poser camera) but when I try and move v4 into my scene the whole thing moves is there away to keep the scene where it is and just move v4 into it? I don't really want to change the camera angle as I have the scene just right.
  • Richard HaseltineRichard Haseltine Posts: 111,788
    You should switch to another camera (the pose camera is better used for this sort of job, keeping the main camera for you actual renders, by the way as the Pose camera isn't tracked for undos) so that you can see the sceen as a whole, then position V4, an finally switch back to the camera you want to use for rendering.
  • beachlegsbeachlegs Posts: 531
    Thank you Richard I ended up doing just that :) I appreciate your help thanks again :)
