Adjust rigging to shape
I transferered a morph from G8m to G8f using transfer utility and it turned out pretty well, but when I tried to adjust rigging to shape to view went all crazy and I can not find g8f anymore. She is still in the scene tab I tried the view frame button but still do not see her
  • plasma_ringplasma_ring Posts: 1,027
    Are you using this method or similar? I've poked buttons experimentally in ways that made figures "disappear," but as far as I can tell what actually happened is they were warped to such an extreme degree that they could no longer be visibly displayed.
  • Matt_CastleMatt_Castle Posts: 3,249
    Most likely, it was a bad transfer; I've seen this happen when some of the vertices end up with NaN values. (I have no idea how/why it happens, but it does).
    In these cases, I export to OBJ (which replaces the NaN values with zero), then use Blender to select all the vertices at the origin and use Smooth vertex to get them back into (close enough) to the right place. It can then be reimported through the Morph Loader.
