Lack of PC+ HDRI environment
GalaxyGalaxy Posts: 562
edited January 2021 in The Commons
I found only 4 [PC+ HDRI environment] items out of them only 2 are HDRI environment. However if I logged in there is 0 items.
  • Probably means you own them - uncheck the Hide Items I Own box. I would think there were more than four products, though.
  • QuasarQuasar Posts: 700
    Unchecking the hide items I own box in a store search doesn't unhide anything. It seems like items you own are entirely excluded from the search results.
    It works for me. I tried "Yosemite" since we are on the subject of HDRIs, nothing at first and then I unchecked the box and saw packs 1 and 2
    Without logging in to the store, search for "HDR" gave 298 results
  • WolfwoodWolfwood Posts: 997
    Repeat the search. I'm often getting zero results. Then i reapeat and it works.
    Still, most of the time the filter will not work :(
  • GalaxyGalaxy Posts: 562
    (While uncheck the hide items I own) I own all and run out of PC+ HDRI environment. Though I usually use 3d props for interactive scenes and simple environment but HDRIs are helpful for quick and complex environment building.
    @Wolfwood I also often getting zero result for many keyword.
    Example: Some keywords (grow up morph) returning no relevant result and if I uncheck "Hide items I own" then the results are suddenly become zero item.
    @PerttiA Almost all are non PC+ and rarely goes on sale.
  • Dimension Theory has 3 released recently.. https://www.daz3d.com/dimensiontheory ;
  • barbultbarbult Posts: 27,484
    Bad link. Get rid of the semicolon. Should be https://www.daz3d.com/dimensiontheory
