Mesh Grabber not showing in tools
I recently bought Mesh Grabber and it supposedly works with Daz Studo 4.15, however when I look under tools, its not showing up. Anyone know why? Thanks.
  • Did you enter its serial number in Help>About Installed plugins and restart DS?
  • ManFridayManFriday Posts: 569
    Mesh Grabber does not use serial numbers, so there is nothing to enter there.
    The most common cause for it not working is that it wasn't installed correctly. The best way to install it is with DIM. There should be a mf_meshgrab.dll in the plugins subdirectory of your daz studio program directory, and you should see ManFriday's Mesh Grabber in Daz Studio under Help -> Abput Plugins. Is that true for your system?
    Probably just a bad install.. cause it works wonderfully.
    But as long as we have our ManeManFriday around...
    anyway to get the selected polygons to scale?
    I'm having the same issue. I do have the .dll in the plugin directory however I don't see it listed in the Help > About Plugins, nor does it show up in the Tool section of Daz. :(
    I originally installed it via DIM.
    I then tried installing via the stand-alone download.
    Both times I had Daz closed during install and opened Daz when it was comple.
    Any thoughts on what I could try next?
  • plarffplarff Posts: 291
    Did you resolve this issue? I installed via DIMS and nothing. MF Bookmarks works fine but Mesh grabber refuses to install in correct location, so my question is where are the installed files located after running the .exe file to install?
    Oh and NO, there's nothing in Help/About either.
    517 x 105 - 11K
