Lost file?
MynyoriMynyori Posts: 86
I have the slaying dragon file and with it the katana sword that came with it. I was able to find the sword in the sub folders along with the different colors it came with. Now I can't find it even when I search by name. I've tried downloading an reinstalling and I doesn't help. Advice please.
  • Richard HaseltineRichard Haseltine Posts: 111,788
    The Slaying the Dragon set includes daggers but not a sword - are you sure you are thinking of the right set? If you do want one of the daggers, try looking under Poser Formats>your library folder>Props>Daggers in the Content Library pane.
  • MynyoriMynyori Posts: 86
    It's attached to the 'dragon slayer' actor under the actor, wardrobe and prop tab. But I can't find the individual file in the content library.
    never mind. found it under genesis.
    If you use the DAZ Install Manager to install you can find the items in the Installed tab and click the triangle button to their right to get a menu, including the option to view Installed Files which tells which directory they went to and what files were installed there.
