download keeps failing with install manager because of simultaneous update daz software
I purchased my copy of Mousso's Memphis, and when I wanted to download and install - I use Install Manager - Daz also had an update.
Whilst it updated, the download halted, and afterwards I got the message that the download failed,
Tried agin, and again ... must have tried ten, twelve times, and each time the download failed.
I assumed this might be a server problem, so I came to the site and tried manual download. Within fiv seconds or so I had my download.
So, my conclusion is that it is not the server but Daz installing its update whilst downloading.
  • to make it even weirder: whilst downloading for manual install, it also installed through Install Manager...
    so the files are installed but the problem is not solved ...
  • SevrinSevrin Posts: 6,314
    Whenever there's an update to DS, I download and install that separately from anything else. With DS completely shut down. And fingers crossed.
  • I'm not following exactly what happened - did the DIM download eventually succeed or not?
  • I'll try to  be more clear:
    1/ I purchase Mousso's Memphis and open Install manager to install it
    2/ I notice Daz software has an update.
    3/ I start the download and installation proces
    4/ I notice the Daz installer also downloads and is ready before Memphis.
    5/ The software update begins to install (Windows 10, latest) and the Memphis download stops.
    6/ when the update is installed, I assume the download will continue but it stops with the message that the download has failed.
    7/ I assume this is because of the interruption, and try again8 the download keeps on failing
    8/ I try closing install manager and open it again - DAZ is not open! but that does not help
    9/  after several attempts, I close down my puter and reboot, then try again. Download failed.
    10/ After several attempts, I decide to come hereto the forum and see whether the servers are overloaded or ... ?  But nothing...
    11/ so I decide to open this thread with the first post. Meanwhile another attempt to download via Install Manager is running.
    12/ I go back to my puter and notice the download is slow and stopping (around 18%)
    13/ I decide to download and install manually.
    14/ manual install works perfectly, and the zip downloads in a few seconds.
    15/ when I look at Install manager, there is no message of a failed download, on the conrary. And when I open Daz soft, the file has been installed. So I come back here to add the second post.
    So: yes, it is installed. But it is *not!* a good idea to let the software update and at the same time download a file.
    Lesson learned.
    Perhaps it would be a bnetter idea for DAZ to warn users of an udate without waiting untll they want to download a purchase.
    Or, for users to download manually and stop using download and install software.
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    edited January 2021
    A DIM download failing for no (obvious) reason has been rather common since end of October, although currently I experience the DIM downloads to be rather stable. I donÄt think that the failed download has anything to do with the parallel insatll of the Studio update. It was just coincidence. I do agree, though, that all downloads and content installs should be suspended by DIM when a new version of Studio is installed. It has potential for quite some damage to the CMS if things really go bad.
    Post edited by Mark_e593e0a5 on
  • AscaniaAscania Posts: 1,856
    I'm currently experiencing that issue of constant download failures as well, without any D|S update. Although, DIM wants to update and keeps failing at that too.
  • TaozTaoz Posts: 10,346
    edited January 2021
    DIM just said there was an update when I started it earlier today, but after the update (or whatever it did) it still had the same version number.  Has happened a few times before but that's a while ago.
    Post edited by Taoz on
