1.7.21_How to Hide Light Geometry from Spotlights?
Hey all is there a way to get rid of/hide the Spotlight's Light Geometry?
When its set to anything other than Point it creates this black geo that doesnt go away in render either
Heres what it looks like, I just setup a bunch of lighting and for the ones set to rectangle geo you can see that the black boxes appear in the render window
https://ibb.co/b1cMBGM
Any ideas how to get rid of/hide this?
  • ZilvergrafixZilvergrafix Posts: 1,385
    Set Opacity value to 0.0001, that is the most minimum value accepted in daz for almost invisible emissive geometry
  • PlatnumkPlatnumk Posts: 682
    edited January 2021
    Select the light in queston in the scene pane then goto the Parameters Pane - Light & switch the Render Emitter to OFF
    Post edited by Platnumk on
  • SevrinSevrin Posts: 6,314
    Spotlights  =| emissives
    That will often turn the spoltlight off. Better to set "Visible in Render" to OFF
