Objects invisble in viewport
juanjoharojuanjoharo Posts: 92
Hi, until today i've been working in a scene without any problem but when i open the file now the objects are in the scene but in the viewport they are invisible, not hiden but i can't see them, if I render the scene, it renders normally so the objects are there but obviously i can't work with them
Other files open Ok
Any idea about this...
Thanks for help
  • Cayman StudiosCayman Studios Posts: 1,141
    It sounds the DrawStyle menu option may have been changed to "Wire Bounding Box" (see attached picture).
    540 x 440 - 57K
  • juanjoharojuanjoharo Posts: 92
    Hi, the drawstyle does not affect this issue, no matter while you choose, you can't see anything in the viewport. I just discovered that loading the scene with "merge..." makes the scene appears ok, but right now i'm working in a new file and this isuue happens too with the merge command.
    Is a big problem, cause i can't work in any new or old job
    I can't think of any reason that would happen. Why Merge works when a simple loading of the Scene doesn't, very strange.
    One thing you could try though, is to change to a different layout Style, using the Window menu. If that works, change back to your original style from the same menu.
