Genesis 3 to Genesis 8 Pose Converter
I'm looking for instructions on how to use Genesis 3 to Genesis 8 Pose Converter. I can't figure it out. Thanks for your help.
  • I did not buy that one, but normally there's a readme, guide or manual in the zip folder of the product.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,804
    edited January 2021
    you can also just pose genesis 8 with 3 poses for free by just using the pose controls for arms up 45° legs out 6° on genesis 3 poses
  • Thank you. The software doesn't have a guide.
  • It's pretty straightforward, at least to me.
    "Converted files directory"
    Top box selects the output directory.
    Below that opens the output directory selected in the top box
    The central area shows the poses to be converted.
    The "Add individual pose files" opens a file explorer to allow you to select individual poses to convert.
    The "Add pose directory" allows you to batch convert an(or multiple) folders containing poses, in one button push.
    "Remove selected": if you select individual files, or groups of files(using ctrl+Left click), which have an orange highlight(by default) you can remove them, leaving the rest for conversion.
    "Clear all" clears the entire list of poses to convert.
    "convert files" starts the process. Push this and go have a coffee, it may take a while, depending on the number of files selected and the single thread speed of your computer.
    "Create metadata" produces a suppport file for smart content. if it's unchecked metadata files won't be created.
    If you click on the question mark in the lower left corner and then click on the individual items, it'll provide you the same information i just wrote.
    If you have a more specific question, i'll be lurking around.
