How 3ds Max export Realflow fluid animation obj sequence import DAZ Studio
Have related plugin or script?
Post edited by LiPeng on
Morph Loader Advanced should allow you to load an OBJ sequence as a series of morphs for the first object you load. Uncheck the "SIngle File" option under the General header, then under the Batch header select your OBJs. Morph Loader used to be buggy, though (while Morph Loader Pro worked fine), but I have never used it myself since its overhaul, so I don't know if it works fine now.
