Tracking down V6 shape for Genesis 2
srieschsriesch Posts: 4,243
edited September 2014 in Daz Studio Discussion
- I can't seem to locate the Victoria 6 shape for Genesis 2; where is it?. (I don't normally use Genesis 2 or V6 at the moment but have them installed and wanted to quick check something.)
- under Genesis 2 Female > Actor, there is no "Female > Real World" or any subcategories. Are these just different, or should I be seeing a Victoria 6 parameter there ? I tried selecting "Genesis 2 Female" and then searching for " "Victoria 6", but it doesn't find anything. (I should still be able to see the V6 morphs under Genesis 2 even though I didn't actually load V6, correct?)
- For comparison, in the Parameters tab, under Genesis > Actor > Female > Real World, which is where I thought it would be, I have
Basic female
Stephanie 3
Victoria 3
Victoria 4
Victoria 5
Victoria 5 Supermodel
Voluptuous
Also, "Victoria 6" isn't listed in the Content Library Pane under Products > V. Should it be? I know not all products are listed here, so I'm not sure if this is normal or an indication that something's missing. DIM shows the product as installed, so I didn't just forget to install it by accident, although I don't know where the content thumbnail went or what it's named, and I can't search for my guess of "Victoria 6.duf"
Post edited by sriesch on
  • frank0314frank0314 Posts: 15,094
    V6 is located in My DAZ 3d Library/People/Genesis 2 Female/Characters. Assuming your using DIM to install your packs
    Post edited by frank0314 on
    In DS, she's under Actor > People. Her separate morphs are under Actor > Full Body > People > Real World, and Actor > Head > People > Real World.
  • srieschsriesch Posts: 4,243
    Hmm. Ok, so something's messed up on my end then, because there is no People nor "Full Body" under "Genesis 2 Female" > Actor. Actor has only Head, "Lower Body", and "Upper Body", nothing else.
    The file "Victoria 6.duf" is there (well, a different base path for me than this since I don't install into the default location, but the file exists anyway.)
    Are G2F and V6 installed in the same library?
    Post edited by Lissa_xyz on
    EDITED
    In the content library pane, navigate to library > People > Genesis 2 Female > Characters. Is the Victoria 6.duf icon in there?
    /edit
    Looks like you edited your previous post. Did you figure it out?
    Got it. Thanks Vaskania, for making me double-check things. Somehow I lost a content folder mapping. Turns out I had G2F mapped in TWO locations, so I didn't realize the folder with G2 base and V6 was currently unmapped since I could still see G2F. After remapping and re-running the search for new content, everything is now working as expected, and I have my "Victoria 6" morph now.
    NP. You only have 1 mapped directory with G2F now though, right? Having multiple installs of G2F mapped at the same time will cause issues.
    Actually I still have 2 mapped. What problems will that cause? I thought it just used whichever was marked as the preferred file, and ignored the other file.
    Sorry, I guess it won't. According to this post, Genesis figures don't have the issues Gen4 did.
