Bathroom Discussion
For the story that I'm trying to write, I want everything to be as detailed as possible, and I'm working it one room at a time. I'm currently in the bathroom, and I did find a lot of products that match what it is that I'm trying to do, but without knowing more specifics about some of the props, I'm a bit lost.
For this one:
https://www.daz3d.com/small-room-kit-bathroom-props
Do the cabinets under the sink open up? This set literally has everything I need, but I do need to know if those cabinets open.
For this one:
https://www.daz3d.com/cosy-bathroom-with-rigged-shower-and-poses-for-genesis-8-female
The only thing that I really need out of that is the shower bit, cause it's movable. But my question is can it be separated from the wall that it's attached to?
For this one:
https://www.daz3d.com/bathroom-and-laundry-area-set-with-props
It's the same deal, as whether or not the cabinets open up and if the shower peice (the shower head, the lever for it, etc) can be disconnected from the wall that it's attached to.
Overall though, my best bet looks like it would be one of these two
https://www.daz3d.com/lovable-bathroom
or
https://www.daz3d.com/top-floor-bathroom
Thing is though that with the second one, I'm not sure if the shower is detachable from the wall it's attached to. The first link clearly shows in images of the props that you can separate it from the wall. While the second one doesn't. While I know that normally means that you can't, I've found out from a couple of other sets that just cause they don't include an image showing it as being able to be separated doesn't mean that it can't be.
  • chris-2599934chris-2599934 Posts: 1,986
    edited January 2021
    I don't have the other products, but I can answer your question with respect to Small Room Kit: Bathroom Props.
    The doors aren't rigged and can't be opened out of the box. However, the interiors of the cabinets are modelled, so you could potentially make the doors openable if you're willing to put some time in with the Geometry Editor to split them out into separate objects.
    Post edited by chris-2599934 on
  • AscaniaAscania Posts: 1,856
    Gemini Queen said:
    For this one:
    It can be loaded on its own. No need to detach it from the wall.
