3delight error message 141
Ravioli777Ravioli777 Posts: 9
This seemingly harmless message results in no render most times, total slow down the rest. Reset daz to defaults to no avail, however did recently get a new rig with more ram and a way better vid card; nvidia geforce 750 ti.
Anyone have any ideas?
    It may be to do with your graphics card driver and pixel settings, have a look here : http://www.daz3d.com/forums/discussion/42049/
    and here : http://www.daz3d.com/forums/discussion/25643/
  • BejaymacBejaymac Posts: 2,002
    We need to know the full error number before we can help decipher it, it should look something like - "3Delight message #43 (Severity 0): R2093:"
    It's that letter and four digit number right at the end we really need.
  • V3DigitimesV3Digitimes Posts: 3,459
    Error 141 :
    When you make a render in the progressive mode render settings, it will automatically reset your filter to a box because of the way 3Delight handles it. Is it your case. If yes just uncheck progressive rendering. If no, I never saw that before. But keeping progressive for development stages of a render is an excellent idea.
    Don't bother about that. Many creators building shaders or even defining surface will "kill" or just "brake" the displacement in order to avoid offsets. This tend to make 3Delight perplex, but never mind, 3Delight is just informing you that it does not understand why you did that with the disp. But will render exactly the way it is supposed to.
