Daz Dynamic Clothes Error
VincentXyoojVincentXyooj Posts: 56
It would seem that I run into many errors on DAZ 3D... I have recently purchased dynamic content in for my runtime,
and for some reason when I load the model, only the rig shows up and the product its-self is gone, does anyone know
how to resolve this issue?
    Can you give a link to the product? What version of DS are you using? Are you using the built in player or Cloth Control plugin? What model are you attempting to use it with?
    The more information you can give the easier it will be for someone to help you.
  • VincentXyoojVincentXyooj Posts: 56
    Okay np,
    These are the products that I have purchased. Some of them I got a while back, but never tested them till now http://www.daz3d.com/sailor-girl, I recently got this one and it doesnt work at all... Only rig files appear.
    http://www.daz3d.com/dynamic-sporty-for-v5
    http://www.daz3d.com/dynamic-gymrat-regular-size
    I enjoyed using these products, but now for some reason they fail to load when I click on them, the file loads, but we only have the rig file, and the product is gone... The surface tab doesn't even have any materials.
    I wanted to use them on genesis and genesis 2, I was able to do so before but now... I can't even do it
  • SimonWMSimonWM Posts: 924
    Check that your DAZ Studio version matches with your Optitex Dynamic Clothes plugin version. What you are experiencing happens when you have mix-matched versions. The last numbers of both must match.
  • Sphinx MagooSphinx Magoo Posts: 587
    I have a problem with dynamic clothes as well. The clothes are falling through the figure. I'm using this package (http://www.daz3d.com/dynamic-supersuit-set-1-worlds-finest).
    Could it be the morphs I'm using? The morphs on my Genesis figure make it so that the figure pokes through the shirt of the SuperStrongCapeM5Hero figure. The clothes make no attempt to wrap around the figure. Also, I have the Supersuit loaded as well. Would that make a difference?
    Check that you are only colliding with the figure. That happens when your "collide with" list includes things like buildings (props) or too many figures.
  • Lord MajesticLord Majestic Posts: 51
    I've had this issue, reinstalling the dynamic clothing control plug-in fixed it.
  • SlimerJSpudSlimerJSpud Posts: 1,456
    Is it still true that the Optitex dynamic clothes plugin is only for the 32 bit version of Daz Studio? The behavior the OP described is like what happened when I loaded a dynamic item into 64 bit DS3. Apologies if this info is out of date.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    edited September 2014
    OptiTex has, as I recall, always worked in the 64 bit versions of DS. It's the embedded Mimic derivative that's 32 bit only. Edit: well, on reflection maybe not always - but certainly for a long time.
    In DS4+ it's always been both, in DS3 the Mac version was 32-bit only.
    I was told in DS3, it was 32 bit only for Windoze PCs as well. I'm running DS3 and there is no Optitex plugin for the 64 bit version. Good to know this is fixed in the later versions (which I should switch to sometime this century).
