Why would a .duf mat file say V6 uv set not found, when it clearly is there?
jakibluejakiblue Posts: 7,281
Curious about what causes this.
When applying the full skin .duf mat file to a character, why would DS throw up a message saying:
"some assets needed to load the file were missing. The content may not work as expected. The file that could not be found:
/My Library/data/DAZ 3D/Genesis 2/Female/UV Sets/DAZ 3D/Base/Victoria 6.dsf
...when the Victoria 6.dsf is very much clearly there in that exact file path?
    The path in the error message has "My Library" that shouldn't be included if the preset was saved from a properly mapped content library.
    Ah! thank you. So it should really just start with the /data bit?
  • BejaymacBejaymac Posts: 2,010
    Yes, DS will always search inside it's listed content directories, so any poorly done pathways will screw things up.
