Rigging Frustration
The more I try to use this program the more I wonder why. Anyway, I finally found a flight suit that I could put on my figure, which is great, except that when I put it on the figure, it moves and changes size dramatically. This makes no sense to me, as it's correct before I use the transfer utility, and I do exactly as the tutorial said online. Can someone shed some light on this before I dump this software and go back to hand drawings rather then try and use it?
  • BejaymacBejaymac Posts: 2,002
    If it's a freebie then a link to the suit would help understand where your going wrong.
  • Richard HaseltineRichard Haseltine Posts: 111,306
    If you are using the Transfer utility to rig a piece of clothing, as an imported OBJ, for a figure it wasn't made for then you must make sure that it is correctly sized and positioned as imported. I suspect you are using an inappropriate preset when importing the OBJ (if it's Poser format clothing then you need to use the Poser preset in the OBJ importer options dialogue).
