Prop keep asking for a folder that I did not setup as content
Hello all, I got a bit of a problem, thank you in advance to anyone who might help me.
I've manually installed an item, and everytime I try to use it, it tells me it cannot locate the .obj
Looking around, apparently it could be because of the folder location setup. So I went and checked:
The path for the menu item in DAZ is:
E:\Programmes\DAZ\My Daz3d Library\Runtime\Libraries\Props\FreeFashion\EckbankSetModern\Eckbank_Modern.pp2
And the path to the .obj is:
E:\Programmes\DAZ\My Daz3d Library\Runtime\Geometries\FreeFashion\EckbankSetModern\Eckbank_Modern.obj
AND
E:\Programmes\DAZ\My Daz3d Library\Runtime\Libraries\Character\FreeFashion\EckbankSetModern\Eckbank_Modern.obj
Because in doubt, I went and duplicated the file in both location. It did not help.
It's the only object I have which does that? I don't understand why it ask me for a folder I didn't setup, and which doesn't exist (cannot exist, I never used poser in the first place), but I'm pretty sure that's part of the whole reason it's not working.
If anyone has a guess as to what's going on, I'm all ears
thanks again
  • OmnifluxOmniflux Posts: 442
    The prop was created incorrectly. The path it is looking for existed on the creators system.
    If you edit the file "E:\Programmes\DAZ\My Daz3d Library\Runtime\Libraries\Props\FreeFashion\EckbankSetModern\Eckbank_Modern.pp2" and search for the string "C:\Program Files (X86)\Poser 7\Runtime\Libraries\character\FreeFashion\EckbankSetModern\Eckbank_Modern.obj" and replace it with "Runtime:Libraries:Character:FreeFashion:EckbankSetModern:Eckbank_Modern.obj" it should resolve the issue.
    That is not the only mistake the creator has done.
    The *.obj files should be saved under ...\Runtime\Geometries\...
  • AscaniaAscania Posts: 1,856
    A bad habit that can even be found in Poser itself.
  • I did as you all suggested and changed the path in the file, and it now works perfectly!
    thank you everyone!! laugh
